Delete a Server
A Server contains the Server Roles that support WFO applications and features. Use caution when deleting servers. Deleting servers can cause applications to stop functioning.
Before you begin
Read Deleting Servers from the installations tree.
Procedure
Go to System Management .Under Enterprise, select Settings.
In the Installations tree (left pane), select the Server node you want to delete, expanding Site Groups or Sites as necessary.
Click the Server Roles tab.
Click Select None to clear all check marks from the Active column for all server roles.
Click Save (to deactivate the server roles).
When prompted with Do you want to continue, click Yes.
Wait for the Pending Messages icon
to disappear from the screen before continuing to the next step. (The icon disappears when the configuration message that deletes the server roles is successfully sent to the server.) -
Click the Settings tab.
Click Delete.
Create and manage Installations tree nodes
