Delete an application server
Delete an application server, if needed. Deleting an application server includes all of the steps described in deleting a generic server, in addition to other steps.
Before you begin
Procedure
  1. Complete the steps described in Delete a Server.
  2. To clean up the APPSERVER table in the BPMAINDB database:
    1. To find an old Application Server ID that was deleted from System Management Module that allows performing suite-wide system management activities from a single, Web-based application, the Enterprise Manager., Enterprise, and Settings, run the following SQL script:
      SELECT * FROM APPSERVER
    2. To delete the old Application Server from the table, run the following SQL script:
      DELETE FROM APPSERVER ID WHERE ID = ID of the old Application Server
  3. To clean up the LOGSERVER table in the BPMAINDB database:
    1. To find an old Application Server ID that was deleted from System Management, Enterprise, and Settings, run the following SQL script:
      SELECT * FROM LOGSERVER
      DELETE FROM LOGSERVER WHERE ID = ID of the old Application Server
  4. Perform the ADAM Clean Up, which deletes the old application server that was deleted from System Management, Enterprise, and Settings:
    1. From the Database Management Server, run ADSIEDIT.msc.
    2. From Connection Settings, under Connection Point and Select a well known Naming Context, select Configuration.
    3. From Computer and Select or type a domain or server: (Server | Domain [:port]), select localhost:50000.
    4. Click Ok.
      Connection Settings
    5. Expand Configuration > CN=Configuration > CN=Sites > CN=Default-first-Site-Name > CN=Servers.
    6. From the servers list, locate and delete only the old application server that was deleted from System Management, Enterprise, and Settings.
      Servers list
Delete a Server
Deleting Servers from the installations tree
