Delete a Site Group or Site node
You can delete Site Group or Site nodes from the Installations tree.
Use caution when deleting Site Group or Site nodes.
  • If you delete a Site Group node, or a Site node, all its child nodes including Servers, are also deleted.
  • You cannot automatically restore a deleted Server back to the Installations tree.
    To restore a deleted Server, manually add the Server back to an existing Installations tree node, and then manually reconfigure the server.
Procedure
  1. Go to System Management .Under Enterprise, select Settings.
  2. Do one of the following:
    • Delete a Site Group node - In the Installations tree (left pane), select the Site Group you want to delete.
    • Delete a Site node - In the Installations tree (left pane), select the Site you want to delete.
  3. Click Delete.
Delete a Server
Create and manage Installations tree nodes
Moving an Installations tree node
Manage the Installations tree
Deleting Servers
