Create a Site
To represent a facility or location in your enterprise at which physical servers are installed, create a Site.
Procedure
  1. Go to System Management .Under Enterprise, select Settings.
  2. In the Installations tree (left pane), select either the Enterprise node or the Site Group node under which you want to create the Site.
  3. Click Create Site.
  4. Complete the Name and Description fields. The values for these fields are at your discretion.
  5. If you are creating a Site in a multi-tenant SaaS environment, specify a Tenant to which you want to associate the Site. Specify Shared for the Tenant if the Site will contain hosted servers or data center zone Logical deployment zone that serves as the centralized, single point of access where application data and content metadata is accessed, managed and maintained. servers.
  6. Click Save.
Creating Sites
