View all instances of an active alarm
You can display all the instances of a specific active alarm in the Instances pane of the Alarm Dashboard.
Procedure
  1. Click System Monitoring > System Monitor > Alarm Dashboard.
  2. In the Enterprise Alarms pane, click the specific alarm whose instances you want to view.
  3. To display the list of alarm instances, click Instances in the lower left of the dashboard Suite-wide unified dashboard that provides a single, quick view of valuable information across multiple applications..
    If the Instances text appears in a blue font (rather than black) when you point to it with the mouse, the Instances pane is already selected.
    If you click a specific instance of an alarm in the Instances pane, details about the alarm instance display in the Details pane on the right.
    A small arrow icon appears at the top of a column to indicate when the column is sorted in ascending Ascending sort icon or descending Descending sort icon order.
    Use the Filter options in the left pane to display only active alarms that meet specific criteria.
    Use the Page controls at the bottom of a pane to page through multiple pages of alarms.
Viewing all instances of an active alarm
Instances pane reference
