Configure Rule Settings
Define the name, engine type or types to associate with the Recorder Analytics Rule, and enable the rule to activate it.
Before you begin
Review Rule settings
Procedure
Select Recording Management. Go to Recorder Analytics Rules, and select Recorder Analytics Rules.
Select Rule Settings.
Click
Create new Rule.
Define the General settings:
Enter a Name for the rule.
Optional. Enter a meaningful Description for the rule.
For multi-tenant systems, do one of the following to select the Tenant to whom to associate the Recorder Analytics Rule:
To assign to a specific provider, select Reserved for Provider.
To assign to a specific tenant, select the tenant.
To assign to all tenants, select All.
To activate the rule, select Enabled.
Select one or more Engine Types, as appropriate:
Metadata Detection: To perform Metadata Detection.
Real-Time Acoustics: To detect silence time or cross-talk in interactions, and activate real-time assistance.
Real-time Linguistics (remote): To detect terms spoken in predefined real-time categories, or custom real-time categories for users with Speech Analytics, and activate real-time assistance. With this engine, analytics processing is performed in the cloud rather than on the server on which an interaction In Speech Analytics, an interaction represents a single part of the contact between one employee and the same customer. In Text Analytics, an interaction is the communication session between one or more employees and the same customer with a unifying contextual element. is recorded.
Real-Time Speech Analytics: To detect terms spoken in predefined real-time categories, or custom real-time categories for users with Speech Analytics, and activate real-time assistance. With this engine, analytics processing is performed locally on the server on which an interaction is recorded.
Risk Assessment: To implement the Risk Assessment Tactical solution, when voice biometrics is deployed in conjunction with the Victrio Management service.
Voice Biometrics: To perform identity verification Feature in voice biometrics where the speaker’s voice is compared to a collection of employee or customer voiceprints that should match the call. If a match occurs, the speaker is said to be verified. or target detection Function of the IAFD product that compares a caller’s voice to one or more voiceprints in a watch list to detect if a target is participating in a call..
Voice Enrollment: To perform automatic enrollment Process in the IAFD product where an employee, customer, or target is registered and the system is then able to assist with identity verification and watch list detection when that speaker is on a call..
To verify that there are no configuration issues, do the following:
To detect configuration problems with recording systems, click
Check Configuration .
To see the status of configuration changes the Enterprise Manager application is currently processing, click
Configuration Messages Status .
Click
Save Changes .
What to do next
