Configure Actions
Configure the actions to trigger for the Recorder Analytics Rule when the conditions configured for the rule are met, and the action frequency. You can configure single or multiple actions for the same rule. To assign the interactions to a folder, to tag attributes, or send notifications, you must predefine folders, custom data attributes, and the notification settings
Configuring the Actions screen is optional if you are creating a Recorder Analytics Rule that performs automatic enrollment Process in the IAFD product where an employee, customer, or target is registered and the system is then able to assist with identity verification and watch list detection when that speaker is on a call.. It is not mandatory for a Recorder Analytics Rule to execute actions when automatic enrollment operations occur on interactions.
For verification Feature in voice biometrics where the speaker’s voice is compared to a collection of employee or customer voiceprints that should match the call. If a match occurs, the speaker is said to be verified. and detection Function of the IAFD product that compares a caller’s voice to one or more voiceprints in a watch list to detect if a target is participating in a call., you most likely will require actions based on the verification or detection result.
For automatic enrollment, you can configure actions; however, the enrollment activity itself can be viewed as the rule’s action. Therefore, actions for enrollment rules are optional.
Before you begin
Procedure
  1. Select Actions.
  2. Select the Action Frequency:
  3. To define Rule Actions, select Create New Action icon Create New Action.
  4. From the Action Type list, select the action to execute when the rule conditions are met:
    • To assign the interaction to a predefined case, select Assign Call to Case and then select the Case to which to assign the interaction.
    • To post the XML file with the set of interactions that matched the rule, select External URL, and in the URL field, type the URL.
    • To send notifications to employees by email or desktop pop-ups, select Notify Using Alert Rule, and then select the Alert Rule that matches the engine.
    • To tag a Custom Data field to the interaction metadata, select Tag the Attribute, and then select the Attribute and define the Value to assign to the attribute.
      In a Multi-Tenant SaaS environment, the tenant to which a custom attribute belongs appears in parentheses next to the custom attribute. (When a tenant user creates a custom attribute, the custom attribute is automatically assigned to the same tenant as the tenant user.)
  5. Click Save icon Save Changes .
