Set Server Role Associations
Most server roles are automatically associated with the appropriate roles, or associations that are set by default, based on product licensing. It is best practice in general not change these associations.
However, in some cases In Risk Management, use cases to group interactionss according to the needs of the enterprise. Interactions can reside in multiple cases simultaneously. you must set associations for a server role Entity that contains a logical, predefined set of components (system software or certified third-party software) deployed in the Data Center and Site Zones that provide specific functionality for the system. manually.
The Enterprise Manager generates an alarm if mandatory associations are not set or are deactivated.
Complete this procedure to set associations for a server.
Procedure
  1. Select the server role you configured and click the Associations tab.
    The Associations (Server Role Name) screen opens on the right panel, showing the roles that can be associated with your selected server role.
    By default, many of the server roles’ associated roles are already selected. And when the check box is inactive (greyed out), the association is a mandatory one.
    It is not recommended that you de-select a mandatory association, since that may result in Workforce Optimization (or Enterprise Suite) not working properly.
  2. You can do one of the following:
    • If you need to select a role to be associated with the server role, select the check box beside the associated role’s name.
    • If you need to remove an association from the server role, clear the check box beside the associated role’s name.
Configure Server Roles
