Other Configuration Settings
Enterprise Manager is not limited to configuring only managed servers and server roles.
The menus listed here contain many other settings that you configure using Enterprise Manager:
Similar to the server role Entity that contains a logical, predefined set of components (system software or certified third-party software) deployed in the Data Center and Site Zones that provide specific functionality for the system. settings, Enterprise Manager also uses XML files to manage the settings available from the screens displayed from these menus. Enterprise Manager also maintains these settings in XML files.
The settings available from these menus do not use the XML metadata and XML instance data structure used for the server roles. The configuration settings for the tabs available from these menus are stored in a single XML file with a name that describes the settings.
For example, the settings in the System Management, Enterprise, Enterprise Settings screen are stored in the enterprisesettings.xml file. The settings in the System Management, Enterprise, Security screen are stored in the securitysettings.xml file.
These XML files are also stored in the Framework Database Server role in the Data Center (also known as BPMain) that stores user, organization and group data, including user preferences and security data (roles, permissions, and license information)..
Handling of Configuration Changes by the Enterprise Manager
Enterprise Manager Agent application
