Manually assign a serial number to a recorder server
You can manually assign a serial number to a recorder server. Manually assign a serial number to a recorder server when you are upgrading a recorder server by replacing an existing server with a new server.
Before you begin
Procedure
  1. Go to System Management. Under Enterprise, select Settings.
  2. In the Installations tree (left pane), select the recorder server to which you want to assign a serial number.
  3. Select More Actions, then select Add Serial Number.
  4. Enter the serial number you want to assign to the recorder server.
  5. Click Save.
Manually assigning a serial number to a recorder server
"Recorders Upgrade section" (WFO 11.1 SP 1 to V15.2 Migration Guide)
