Enable HTTPS
To enable HTTPS encryption of all data that is transmitted on the network by all applications and servers in the system, complete this procedure.
Procedure
Go to System Management . Under Enterprise, select Security.
In the Installations tree (left pane), select the Enterprise node, a Site Group node, or a Site node where you want to enable HTTPS.
Select the Enterprise node to encrypt data transmitted on the network by all applications and all servers in the enterprise.
Select a Site Group or Site node to encrypt only the data transmitted on the network by the applications and servers that reside under the selected node.
If collapsed, expand the HTTPS section.
Select Enable HTTPS.
Select the HTTPS Protocol and Cipher Configuration. The default setting is Intermediate. Set to Modern for highest security and to harden the system. Custom mode is restricted. This mode is for troubleshooting purposes only and is only for Verint Technical Support.
Click Save or Save and Apply to Children as appropriate.
Security settings screen reference
Security configuration procedures
Save, Save and Apply to Children, Revert to Parent, and Revert Buttons
Security Configuration Guide
