Configure the Enable CSRF Defense setting
Select the Enable CSRF Defense setting to enhance security by protecting against cross-site request forgery (CSRF) attacks. This setting enables adding tokens for double submit cookie cross-site request forgery (CSRF) protection.
Go to System Management . Under Enterprise, select Settings.
In the Installations tree (left pane), select the Enterprise node.
Click Security.
In the Application Security section, select Enable CSRF Defense to protect against cross-site request forgery (CSRF) attacks. (The setting is selected by default.)
Clear the check mark from Enable CSRF Defense setting to make the cross-site request forgery defense unavailable.
Click Save.
Security settings screen reference
Security configuration procedures
Save, Save and Apply to Children, Revert to Parent, and Revert Buttons
