Configure the Key Management Server settings
To enable applications and servers in the enterprise to interact with the Key Management Server, complete this procedure.
Before you begin
Install and configure a Key Management Server before completing this procedure.
Procedure
  1. Go to System Management Module that allows performing suite-wide system management activities from a single, Web-based application, the Enterprise Manager.. Under Enterprise, select Settings.
  2. In the Installations tree (left pane), select the Enterprise node.
  3. Click Security.
  4. In the Encryption Management section, select the KMS Server Type available for your system.
    Options include: AWS, Azure, RSA, Thales CipherTrust KMS, or Thales KMS. Choose Thales KMS when using DSM.
  5. Complete the fields for the selected KMS Server Type, as described in Security setting screen reference, see Related Topics below.
  6. Click Save and Apply to Children.
  7. Check the System Monitoring, System Monitor, Alarm Dashboard screen for new alarms that indicate it is necessary to restart services. If these alarms appear, restart the services indicated by the alarms.
    Alarms indicating it is necessary to restart services sometimes do not appear in the Alarm Dashboard until several minutes after you save the Enterprise Settings changes.
Security settings screen reference
Security configuration procedures
Save, Save and Apply to Children, Revert to Parent, and Revert Buttons
Key Manager Server Installation and Configuration Guide.
