Alarm Configuration Errors in the Alarm Dashboard
Problem:
Alarm Configuration Errors appear in the Alarm Dashboard.
Solution:
To solve this problem, activate the Framework Applications Server role in the Data Center that provides the system’s core applications. It is a mandatory server role in the system and required for all packages. server role Entity that contains a logical, predefined set of components (system software or certified third-party software) deployed in the Data Center and Site Zones that provide specific functionality for the system. on the server that hosts the Enterprise Manager application.
Alarm Configuration Errors can occur when the Enterprise Manager service is running but the Framework Applications server role is not activated on the Enterprise Manager host server.
The Enterprise Manager service must be running before you can activate server roles from Enterprise Manager. Various Alarm Configuration Errors can appear during the period that elapses between the time the Enterprise Manager application is installed and the time that the Framework Applications server role is activated.
Alarm Configuration Errors can also appear if the Framework Applications server role is deactivated at any time.
