XML files modified by Enterprise Manager
As discussed in Handling of Configuration Changes by the Enterprise Manager and Enterprise Manager Agent application, the Enterprise Manager modifies individual XML configuration files. The Enterprise Manager also queues these configuration files in the Framework Database Server role in the Data Center (also known as BPMain) that stores user, organization and group data, including user preferences and security data (roles, permissions, and license information)., and then converts these XML files into a configuration message document. (Enterprise Manager creates one configuration document for each server that has a configuration change.) The Enterprise Manager Agent on a remote server then queries the Enterprise Manager once each minute for these configuration message documents. The Enterprise Manager then sends the configuration message document to the EMA on a server. EMA extracts the individual XML files from the configuration message, and stores the individual XML files in a particular directory on its host server.
This table lists every XML configuration file that EM can modify. The table also shows the directory in which the EMA stores the XML configuration file, and details about the contents of the XML file.
XML file modified by Enterprise Manager |
Directory in which EMA stores the XML file |
XML file contents |
AlarmConfig.xml |
software dir\Conf\Alarms |
Alarm configuration including:
Attributes.xml |
software dir\Conf\Cache |
Attributes configuration including:
AnalyticsRules.xml |
Recorder Analytics Rules configuration. |
BiometricsIdentificationRules.xml |
Identification Rules configuration. |
BusinessRules.xml |
Recording Rules and Calculated Custom Data configuration. |
Campaign-<id>.xml (where id is a unique identifier of a campaign Collection of scheduling periods in WFM, which are defined time periods where specific employees target specific workloads.) |
Central Archive Campaign configuration. |
DataSource-<id>.xml (where id is a unique identifier of a data source Third-party systems that provide data to the system, including employee and device states, and data change events. Typical data sources are phone switches, PBXs, or LANs.) |
Data Source configuration including:
EmployeeGroups.xml |
Employee Group configuration. |
Enterprise-Settings.xml |
Enterprise Settings page configuration. |
LanguageModel.xml |
Language model metadata. |
License.xml |
System Licensing configuration (items licensed in the suite) |
Media-Mime-Types.xml |
Mime types used by the system |
Organization-<id>.xml |
Employee organization configuration including:
Roles-active.xml |
software dir\Conf\Roles |
Active roles on the server. |
role name-conf.xml (where role name is the unique name of a role) |
software dir\Conf\Roles\rolename |
Configuration settings for a particular server role (server role instance data) |
Schedules.xml |
Central Archive Campaign Schedule configuration. |
SecuritySettings.xml |
Security Settings page configuration. |
Servers.xml |
Installations tree server hierarchy configuration including:
XMLNamespaceRegistry.xml |
XML namespaces used throughout the configuration. |
EMLocation.xml |
datadir\EMA\EMLocation.xml |
Contains the address of the Enterprise Manager. The Enterprise Manager Agent (EMA) on a remote server uses this address to query the Enterprise Manager for configuration changes. |
