View the corrective action for an alarm
From the Enterprise Manager Agent Web application installed on every system server that communicates with the Enterprise Manager regarding any configuration changes or alarm messages for the relevant server. (EMA) or Recorder Manager (RM) application on a server, you can view the corrective action steps for a particular alarm.
Procedure
  1. Click System Management > Enterprise > Settings.
  2. In the Installations tree (left pane), select the specific Server node for which you want to view alarms.
  3. Click Launch.
  4. To open the respective application, click either Recorder Manager or Enterprise Manager Agent.
  5. Click Alarms > View Alarms > Active Alarms.
  6. In the Roles pane on the left side, select the Server node to view all active alarms on the server. You can also select a Server Role node to view only the active alarms associated with the selected server role Entity that contains a logical, predefined set of components (system software or certified third-party software) deployed in the Data Center and Site Zones that provide specific functionality for the system..
  7. Select the alarm whose corrective action you want to view, and click View (or just double-click on the alarm). The Active Alarm Details screen displays.
  8. In the Alarm Name column, click the small right-pointing arrow that appears just to the left of the alarm name. This action displays a drop-down list containing the corrective action steps for the alarm.
  9. To correct the condition causing the alarm, perform the corrective action steps.
What to do next
Acknowledge an alarm from EMA or RM
Acknowledge multiple alarms simultaneously from EMA or RM
Active Alarm Details screen reference
Active alarms and the Alarm Dashboard
View active alarms from EMA or RM
