Filter the list of active alarms
Filter the list of active alarms to display only active alarms that meet a specific criteria.
Procedure
Click System Monitoring > System Monitor > Alarm Dashboard.
In the Filter pane on the left side:
To display only the active alarms with that Alarm Name (Alarm Number) in the dashboard Suite-wide unified dashboard that provides a single, quick view of valuable information across multiple applications., select, or type an Alarm Name (or an alarm number).
To display the alarm names of all active alarms in the dashboard, clear the Alarm Name field.
To display only the active alarms triggered by the selected component in the dashboard, select one or more Component Name options.
To display alarms associated with all components in the dashboard, clear the Component Names field.
If you want only the alarms of specific priorities to display in the dashboard, select one or more Priority options.
To display the alarms of all priorities in the dashboard, clear the check marks from all the Priority options.
To display only the alarms associated with the selected nodes in the dashboard, select one or more Installations nodes.
To display the active alarms associated with all nodes in the enterprise in the dashboard, clear the check mark from all Installations nodes.
To display only the desktop alarms in the dashboard, select Show Desktop Alarms. To display the alarms for only one specific desktop, select that desktop from the drop-down list in the Desktop filter option.
To filter the display of the alarms according to all the criteria selected in step 2, click Filter.
(Optional) To clear all filtering settings for all four filter options, click Clear All. If you clear all filtering settings, and then click Filter, all of the active alarms in the enterprise display in the dashboard.
