Standard attributes
The following table lists the standard default attributes used in capturing. You can view the current list of attributes—including both standard and custom—in Enterprise Manager under Recording Management > Custom Data > Attributes.
In this release, the character limit for each field for these attributes is 256. If you had previously mapped an attribute to a custom data field because the field length was insufficient in a previous release, you can now remove the mapping and use the custom data field for something else.
The availability of certain attributes (Call Direction, Called Number, and so on) depends on the following factors,
For the NFAS protocol (supported on DP cards), all the trunks for a specific NFAS group must be on the same Recorder to process signaling properly.
For all protocols, certain attributes are available provided they are present on the trunk bearer channel, and that the trunk span is configured to deliver this information.
See the “Recorder” section in the Technical Overview for more details.
Category |
Attribute |
Description |
Employee |
Employee Group |
The group to which the employee belongs. |
Employee ID |
The Windows login id used by the employee on the workstation. |
Employee Name |
The name of an employee involved in a contact. |
Logged On Duration (seconds) |
The amount of time during which an employee is logged on. |
Network ID |
The user’s network logon ID. |
Organization |
The organization of the employee involved in the interaction. |
Skill |
The employee skill Defined level of knowledge that an employee needs in order to handle a defined workload in WFM. defined on the switch. |
Supervisor Name |
The name of the supervisor associated with a contact. |
Contact
Contact Duration (seconds) |
The duration of the contact in seconds. |
Content Type |
The type of media captured. Supported formats are audio (audio/vnd.verint.wav) and screen (screen/vnd.verint.capb). |
Event Type |
An event in an interaction, at the Employee, System, or CTI level. |
Exception Reason |
You can create a recording rule that marks an interaction meeting the rule criteria as an exception. The Exception Reason field identifies the reason that it is considered an exception. |
Fired Business Rules |
Lists recording rules that have been triggered. |
Interaction Type |
The type of interaction captured. Valid types “Phone” and “Desktop.” |
Number of Conferences |
Total number of conferences in the contact. |
Number of Holds |
Total number of times that the interaction started tracking a held connection for the user. Overlapping, concurrent held connections count as a single continuous hold. |
Number of Transfers |
Total number of transfers that occur over the course of the contact. |
Parties |
All parties involved in the current interaction. |
Pause Duration (seconds) |
The Pause Duration for the contact. |
Time On Hold (seconds) |
The total amount of time, in seconds, that the interaction tracked one or more held connections for the user. |
Wrapup Time |
Indicates how much time the employee spent doing work related to the interaction after the interaction ends. |
CTI |
ANI |
Automatic number identification or Caller ID. |
Call Direction |
The direction of the interaction. |
Call ID |
Unique interaction identifier on the switch. |
Call Reference |
A reference (any string) sent by the Recorder. |
Call Type |
The type of interaction. |
Called Party |
Number of the line to which the interaction was directed. |
Called Party Name |
Employee name associated to the called party or value provided from the switch in the case of Cisco UCM. |
Calling Party |
Number of the line from which the interaction is made. |
Calling Party Name |
Employee name associated to the calling party, or value provided from the switch in the case of Cisco UCM. |
DNIS |
Dialed number identification service (DNIS). The DNIS identifies the number that the caller dialed, which is useful in call centers to which interactions to multiple numbers may be directed. |
Extended Call History |
Provides a history of the interaction states through which the contact has gone. |
Global Call ID |
Globally unique call identifier. This is populated in most environments if the switch or CTI infrastructure supports it. |
Module Number |
The serial number of the Recorder that captured a contact. When used in recording rules, this attribute will contain the serial numbers of all the different captures in an interaction/session. |
Number Dialed |
The actual number dialed by the calling party. |
Queue |
The queues configured on the switch. |
Source Platform |
The source platform Predefined logical group of server roles installed together on a physical server. (such as Facebook, WhatsApp, Instagram) from which an Interaction originated. This attribute is populated by integrations with systems that supply interactions from multiple different platforms, such as Conversocial. For this tagging to be available in a database, a Custom Data field must be mapped to the attribute. |
Device |
Data Source Name |
The name of the switch from which the contact information originates. |
Device Name |
The name of either the primary extension or workstation. |
Extension |
The extension of an employee involved in a contact. |
Primary Extension |
The primary extension of the phone associated with the capture. |
Serial Number |
The serial number of the Recorder for the primary capture of an interaction. |
Workstation |
The name of the employee workstation. |
Import Export |
Extraction Job Name |
The name of the extraction job that extracted the interaction. |
Source Call Identifier |
The unique identifier provided to the interaction by the source capturing system. This identifier is mapped to ensure that the source identifier of each interaction is maintained when the interaction is extracted. |
Source QM Database Server role in the Data Center used to store Quality Monitoring application data. Server |
Not supported. |
Public Safety
ALI |
The Automatic Location Identifier (ALI) contains the location information, such as the street address or GPS coordinates of the caller. |
CAD ID |
The emergency ID supplied by the Computer Aided Dispatch (CAD) software. |
Callback Number |
Phone number for calling back the caller. |
Caller Name |
The name of the caller. |
Caller Number |
The telephone number of the caller. |
Class of Service |
One byte Class of Service characters include: V = VoIP Services default Class of Service (preferably with VOIP being displayed at the PSAP) C = VoIP Residential (preferably with VRES being displayed at the PSAP) D = VoIP Business (preferably with VBUS being displayed at the PSAP) E = VoIP Coin/Pay Phone (preferably with VPAY being displayed at the PSAP) F = VoIP Wireless (preferably with VMBL being displayed at the PSAP) J = VoIP Nomadic (preferably with VNOM being displayed at the PSAP) K = VoIP Enterprise Solutions - Centrex and PBX (preferably with VENT being displayed at the PSAP) |
Emergency Service Number |
Emergency Service Number (ESN) associated with the house number of the street name of the caller. |
GPS Elevation |
GPS elevation coordinate of the mobile caller. |
Latitude |
The latitude coordinate of the mobile caller. |
Local Exchange Carrier |
The Local Exchange Carrier of the caller. |
Longitude |
The longitude coordinate of the mobile caller. |
PSAP ID |
The identifier of the Public Safety Answering Point (PSAP) that handled the referenced call. |
PSAP Name |
The name of the PSAP that handled the referenced call. |
State Province |
The state or province in which the caller is located. |
Street Address |
The street address of the caller. |
ZIP Code |
The zip code of the location of the caller. |
Radio
Emergency Call |
If the call is an emergency call. |
Radio ID |
The ID of the individual radio device on the call. |
Radio Name |
The alias of the individual radio device on the call. |
Radio Network ID |
Unique network identifier of a radio subsystem. |
Radio System ID |
Unique system identifier of a radio subsystem. |
Site |
The radio site ID. |
Talk Group ID |
The ID of the talk group in a group call. |
Talk Group Name |
The alias of the talk group in a group call. |
Zone ID |
The radio zone ID. |
TDM |
Channel Name |
Name of the channel on which the call appears. Used for tagging but not in recording rules. |
Channel Number |
The channel number on which the call appears. |
DTMF Digits |
Dual Tone Multi Frequency (DTMF) Digits apply to the TDM Recorder. DTMF refers to voice-frequency band telephone signaling to call switching centers. |
First Message |
The first message sent by the Recorder. |
Last Message |
The last message sent by the Recorder. |
Third Party |
A message sent by the Recorder in some TDM environments. |
Trunk |
The trunk that the call is on. |
Trunk Group |
The trunk group that the call is on. |
Trading
Turret Name |
The name of a trading turret on a call. |
Turret ID |
The unique identifier of a trading turret on a call. |
Trader Group Name |
The name of the group to which the trader belongs.
Trader Group ID |
The unique identifier of the group to which the trader belongs. |
Line Name |
The name of the line from which the call is made. |
Line ID |
The unique identifier of the line from which the call is made. |
Destination Appearance Number |
The appearance number of the dialed destination. |
Destination Label |
The label of the called destination. |
Recording Reference |
A reference to a recording channel. |
Is Mute |
Is true if part of the call is not supposed to be captured. |
