Multiple registration extension pool member group settings
Used in Avaya DMCC environments with multiple registration, which allows you to have multiple devices associated with a single extension (to a maximum of three devices in total). With Aura 8.0.1 and newer, the multiple registration limit of devices that can be registered to a common extension is increased from 3 to 10.
See the Avaya and Avaya NES Integration with Recorder Guide for more details, including prerequisites and limitations.
Setting |
Description |
Name |
Type a unique name for the member group. |
Description |
Type a description for this extension group (optional). |
Recorder Control Type |
Read-only field that shows Multiple Registration Control for this member group. |
Recorder Fallback Type |
In environments with multiple registration, fallback options are limited to those in which audio recording continues when the CTI or recorder disconnects from the Integration Service. Select one of the following from the drop-down list:
Total Extensions/Total Capacity |
Displays the number of extensions in use, relative to the total capacity. |
Enable Stereo Recording |
Enables recording of separate customer and agent streams for recorded calls. Enabling this feature affects the licensing. For more details, see the related information. |
DMCC Control Type |
The Avaya DMCC Multiple Registration automatically selects dependent and independent modes for the softphones assigned to the local stations. However, you can manually set the control type, if needed. Select one of the following from the drop-down list:
Station Monitoring |
By default, this option is turned off and is accessible only when the DMCC Control Type is set to Automatic. The Verint adapter only captures interactions from registered Avaya stations (softphones). When in Automatic mode, upon startup, the Verint adapter queries Avaya for agent stations. With Station Monitoring off, as agents sign in, the Verint adapter queues station registrations, potentially causing delays in larger systems. A DMCC license is only consumed when softphone stations are active and an agent is logged in, possibly leading to unnecessary alarms in large systems. With Station Monitoring on, the Verint adapter instantly registers all Avaya stations, eliminating registration queues and reducing recording initiation time. However, it consumes a DMCC license for each station, irrespective the status of the stations. Changes you make take effect immediately, without requiring a restart or re-registration of the stations. |
Recording Beep Tone |
Recording Beep Tone: When enabled, participants on a call hear a beep when the Recorder starts recording the call. By default, the beep tone is disabled. To enable this option, select the check box. Note: The duration, pitch, and repetition of the tone are configured in Avaya Communication Manager. |
Advanced Parameters |
Use the Key and Value fields to enter the advanced parameters required for your system. Only add advanced parameters in consultation with Verint Support or Field Engineers. |
When you have finished editing this member group, click Assign & Create Phones, then select one or more phones and click Assign Selected or Assign Range.
Create and edit member groups and extensions
Multiple Registration Licensing Requirements (Recorder Integration Service Avaya Integration Guide)
