Limitations of NIC teaming
Transmit Load Balancing
Balancing the network traffic load on a server can enhance the functionality of the server and the network. Load balancing within NIC teams enables the distribution of traffic amongst the members of a NIC team, so that traffic is routed among all available paths. In IP recording, no data is expected to be transmitted on the NICs used for recording, so the “Transmit Load Balancing” network teaming option is not required for the Recorder NICs and is not supported. “Network Fault Tolerance” only network teaming options are validated and are supported.
Interception NIC
The interception NIC is the NIC used to record calls from the SPAN port. In this mode of recording, a cable from SPAN port is connected to the Recorder NIC. If you want to team the NICs in this mode, you must have identical SPANs configured and connected to each of the teamed NICs. NIC teaming is not supported in Interception mode.
For screen recording, the Integration Service attempts to send screen recordings to the Recorder that is least utilized, when more than one Recorder can record that workstation.
Recorder reference
