Limitations of attribute mapping
Mixed mapping
You may only map attributes to other attributes or to IEMessage fields, but not a mix of the two. So the following is not supported, because it includes both:
MyAttr = event.someUserField1 {+} MyAttr2
Recursive mapping
Recursive mapping is not supported. This means that you may do the following:
MyAttr1 = event.someUserField1
MyAttr2 = event.someUserField2
MyAttr3 = event.someUserField3
MyAttr4 = MyAttr1 {+} MyAttr2
MyAttr5 = MyAttr3 {+} MyAttr2
But you may not then take the created attributes MyAttr4 and MyAttr5 and concatenate them further into yet another field, as in:
MyAttr6 = MyAttr4 {+} MyAttr5
