Genesys SDK
Refer to the Genesys Integration Guide, Cisco Integration Guide or Avaya NES Integration Guide (depending on your environment) for additional information about how to configure Genesys RTP, allowing call recording in environments wherein Genesys uses provided IP information for audio interception.
Procedure
  1. Choose General Setup > Integration Adapters > Settings.
  2. Click Create, then select Genesys SDK Adapter.
  3. Specify settings for this adapter in the right-hand pane, referring to the following table (all fields are required unless otherwise indicated):
    Field
    Adapter Name
    Type a unique name for this adapter. Do not use any special characters or characters that truncate xml. This field is not case sensitive.
    Optional: Type a description of the adapter.
    Adapter Type
    A read-only field that lists the adapter selected above.
    Startup Type
    Select a startup type: Automatic, Manual, or Disabled.
    DataSource
    Select a data source Third-party systems that provide data to the system, including employee and device states, and data change events. Typical data sources are phone switches, PBXs, or LANs..
    T-Server Hostname
    Type the name of the primary Genesys server (set to Verint by default).
    T-Server Port
    Specify the port on which the primary T-Server listens for connections from the clients. 9001 is the default.
    Application Name
    This value is used to identify the Recorder Integration Service in the Genesys logs. It should be a unique value that describes the recording system Process of capturing an employee-customer interaction for playback, screen and dialer-based interactions, and evaluation purposes./server. Verint Recording is the default.
    Use Secondary Server for failover
    Select this check box to use a failover server.
    Secondary T-Server Hostname
    Type the name of the secondary Genesys server (set to verint by default). This field is required if you select the Use Secondary Serverfor failover check box.
    Secondary T-Server Port
    Specify the port on which the secondary T-Server listens for connections from the clients. 9001 is the default. This field is required if you select the Use Secondary Server for failover check box.
    Get RTP Information
    Genesys will provide RTP information if it used with a Cisco switch or Genesys SIP server. To obtain this information you must select this check box. The option is not enabled by default. Only required for CTI Controlled recording.
    RTP Password
    If you have enabled Get RTP Information, type the password configured in Genesys.
    Unique Global Call ID
    Used to associate multiple calls together in a consult, conference, transfer or other multi-call scenario. Select one of the following:
    NetworkCallID/NetworkNodeID
    CallID
    ConnID
    Other
    Note: Although NetworkCallID/NetworkNodeID is an option for this field, there is a known issue with Genesys SDK version 8.0 where this ID won’t work as the Unique Global Call ID.
    Tagging Only
    If this adapter is used in addition to any other call tracking adapters on the same data source and this adapter is expected to only Tag CTI data for the calls that are tracked by another adapter.
    See Default Tagging by the Tagging Only Adapter.
    Process Agent Event
    This option will enable the Genesys adapter to process agent state changes, specifically Agent Login and Logout.
    Event Based After Call Work
    This option will enable the Genesys adapter to stop screen recording based on after call work events, specifically Agent Ready and Logout. Off by default.
  4. Under Advanced Settings, use the Key and Value fields to enter any proprietary pairs that are in use in your system.
  5. Click Save. The adapter appears in the left-hand pane.
  6. Select the adapter in the left-hand pane and click the Start button to start the adapter.
  7. Under the Send Recording Indication to Genesys pane, enable the Recording Indication Feature (off by default) by configuring the following parameters.
    Field
    Select this checkbox to enable the Genesys Recording Indication Feature.
    The Genesys Recording Indication feature prompts the Recorder Integration Service to send a recording identifier back to Genesys for all recorded calls. The Genesys Servers exchange call context with all the KVPs for calls that span more than one Server. If the Genesys Recording Indication feature is enabled, it allows customers to keep recording calls that are transferred across separate PBXs.
    This feature uses theAttachUserData requestofthe Genesys interface to provide the Genesys ConnectionID for the call that is updated, and also provides one or more of the following:
    This feature supports any recording environment with Genesys call tracking adapter or Genesys tag-only adapters.
    Recording Status Key Name
    Enter the Genesys KVP field name (for example Recorded) that contains the key of the recording status (compatibility with v10).
    The Recording Status Key Name field is empty by default.
    Recording Status Value
    Enter the Genesys KVP field name (for example True) that will be tagged as a recording status (compatibility with v10).
    The Recording Status Value Name field is empty by default.
    Primary Recording INUM Key Name
    Enter the Genesys KVP field name that will be updated with the primary recording INUM.
    The default is VerintPrimaryRecordingInum.
    Contact ID Key Name
    Enter the Genesys KVP field name that will be updated with the contact The entire communication experience for a customer, from beginning to end. id of the primary recording INUM.
    The default is VerintContactId.
Tagging Only adapters must be used in conjunction with another CTI adapter. All standard attributes come from the controlling CTI adapter, while those from the Tagging Only adapter are treated as custom data.
The Genesys SDK adapter only processes Agent states (Agent Login, Agent Logout, and so on) and custom attributes, while the other CTI adapter provides information to track calls, recording, and some level of tagging. If you want tagging for any additional attributes, use custom data to capture them as described in the Recorder Configuration and Administration Guide.
Supported Integration Service CTI adapters
