Compliance trunk span member group settings for TDM
Setting |
Description |
Type |
Select a trunk type—the way in which the switch identifies the trunk will determine the type you choose:
Other available options will depend on the switch type you selected in the associated data source Third-party systems that provide data to the system, including employee and device states, and data change events. Typical data sources are phone switches, PBXs, or LANs. (you should refer to the associated Integration Guide for the most up-to-date information):
Name |
Type a unique name for the member group. |
Description |
Type a description for this extension group (optional). |
Port Count |
Specify the number of channels (phone extensions) available on the voice card. |
Associated Dialer Data Source |
Select an existing Dialer data source from the drop down list. This setting allows trunks to be configured between the switch and dialer for the purpose of nailup call identification. |
Recorder Fallback Type |
Select one of the following:
Shared Recorders |
Select one or more Recorders to associate with this Member Group. |
Group Members |
Group Members are the actual channels on a TDM cable (30 on E1, 23/24 on T1). Do one of the following.
Advanced Parameters |
Use the Key and Value fields to enter the advanced parameters required for your system. Only add advanced parameters in consultation with Verint Support or Field Engineers. |
Associate port numbers with extensions for Extension Compliance Trunk Span Member Groups
For TDM trunk spans, the configuration you set for the recorder must match the configuration of the trunk in the existing environment, so that the CTI messages can be associated with the trunk channels for recording. The PBX administrator on site can advise whether the trunks are configured as extensions or not. Typically trunks from the Service Provider will not be extensions. Trunks on dialers or IVRs are sometimes configured as extensions.
Under Group Members, you can associate port numbers with extensions by doing one of the following:
type an extension number (for example, 3344) in each field, then click Save.
or
automatically assign extensions by clicking Generate Extensions, type the Starting Port Number, the total Number of Ports, and the Starting Extension Number, then click Assign.
