Avaya DEFINITY LAN Gateway (DLG)
Use the following procedure to create an adapter for Avaya DEFINITY LAN Gateway (DLG).
Procedure
Choose General Setup > Integration Adapters > Settings.
Click Create.
Select Avaya DLG Adapter.
Specify settings for this adapter in the right-hand pane, referring to the following table (all fields are required unless otherwise indicated):
Field
Server Hostname
Type the hostname or IP address of the AES server or MAPD card on which the DLG link resides. The default is server.
Link Number
Type the number assigned to the DLG link. The default is 1.
Use Backup Server for failover
Select this check box to connect to a backup server if the connection to the primary host fails (enter the server address information in the fields below).
Backup Server Hostname
Type the hostname or IP address of the backup server. The default is server2.
Backup Link Number
Type the number assigned to the DLG link for the backup. The default is 1.
Click Save.
Select the adapter in the left-hand pane and click the Start button to start the adapter.
